05-01-2022, 05:34 PM
Herbert's first car
05-01-2022, 06:44 PM
Perhaps Jim Stringer or the VAR's Archivist?
The best I can offer is a low res scan of this illustration: 1906 first Austin.jpg (Size: 169.63 KB / Downloads: 322) or Robert Johnston's watercolour version used in the 1955 Golden Jubilee book:
05-01-2022, 07:26 PM
Did they leave out the oil baffles? Presume had fixed heads so not a water leak. (With no specifically designed oil rings many Edwardian cars originally produced smoke screens.)
05-01-2022, 08:28 PM
(This post was last modified: 05-01-2022, 08:36 PM by Colin Morgan.)
Not sure how sharp the original would be as it is a close-up of part of the original picture, taken from further away?
This one is a bit clearer... Below is just the car...
05-01-2022, 09:19 PM
Hmmmm... I wonder where that watercolour is....
Thanks Colin and Mike. I will follow up with the VAR suggestion and will be in touch with you Colin by PM in the next couple of days.. Hugh
05-01-2022, 09:50 PM
The watercolour was sold by Bonhams in 2015 for £625.
08-01-2022, 10:36 PM
I notice the front axle is dropped, perhaps anticipating the later sporting Austins. ;-)
Erich in Mukilteo |
