29-12-2021, 08:41 PM
Here is a strange one for you.
Check the pic below.
I've been sorting out some stuff to go on ebay in the new years. And I came across this set of rods. I had these from steve flake a few years ago. And dave flake had had them white metalled about 15 years ago.
Dave obviously chose them because they were a matched set. All are marked with the same engine number, plus over the years they have been stamped 1 to 4. Then 1 dot to 4 dots.
Were things get strange is number 3 rod is totally backwards to the other 3 rods? When you face them all the same way up number 3 little end bolt is on the wrong side.
So did AUSTIN worry which way round they went in the engine?
Tony.
Tony.
