I think its a Panda, Bob.
So what would have caused that originally - levering from a corner?
The rust in the break/seam looks quite long standing.
Yep, I wouldn’t feel too guilty Hedd, it was on its way long before you got to it.
Yes I concluded that too. I'll see if I have a decent H/C head for it.
Bob, its some of the oil barons finest grease. Turns out its blue. Oh, yes and a panda.
Also dug out one of the early dizzys for the chummy (which has a 009 on it presently) so I can work out what is needed to install later this winter. What kind of end do I need for the leads?
[Image: 269777743_10224723249683167_907875905141...e=61C94A54]
Hi RR
Spokes usually break at some stress area. One cause is exposure to acid as in anti rust concoctions.
(22-12-2021, 11:31 PM)Hedd_Jones Wrote: Yes I concluded that too. I'll see if I have a decent H/C head for it.
Hi Hedd
That looks like a DS4 which takes push in connectors.  You’ll have to be prepared for the fact that points, condensers are obsolete. (Parazine gave a good description of hiding a modern condenser in the shell of the old on his R type refurbishment thread). There are also threads describing dizzy caps and rotor arms that can be made to fit, from memory a Ford Y type cap and a Vauxhall Viva (1960s) rotor??
I have seen the base plate modified to take a later DK4A points set.
I have 4 complete assemblies Howard, 2 of which appear rebuilt (that one isn't), with a decent box of bits. So I'm going for it.
So just the standard push in jobbies like on a Bosch clone?
On another note, found a H/C head and gauze for the spare engine. Splendid.
[Image: 269801428_10224726284439034_198963216959...e=61CA2ADF]
Hi Hedd
These sort
https://www.autoelectricsupplies.co.uk/p...ategory/17
Unfortunately out of stock in AES  Sad.
But I’m sure others sell them
Or these:
https://www.gsparkplug.com/4x-ht-brass-p...sh-on.html
Don't feel too bad that corner has been cracked for quite a while from the rust staining.
Just my own opinion Hedd, but as this engine isn’t for your GE, I would go for an lc head, it makes for a much sweeter engine and not half as harsh as as one fitted with an hc head...but then again, you may be planning to race old bluey for all I know!
I’ll get me coat...
