22-08-2017, 04:11 PM
My Car Pics
22-08-2017, 05:24 PM
Very nice , mind that exhaust. What sort of speed would you expect to get out of her. There you are one of the classic questions . What's it worth and how old is it. My grandad didn't learn to drive in one. The
22-08-2017, 06:01 PM
Very tidy, a lovely job.
22-08-2017, 07:12 PM
Excellent,well done... building from scratch is a considerable endeavour.
What's the story with the two piece front beam ?... those headers exit the hood side very nicely and with some purpose. Have you driven on the road yet... how was it ?
22-08-2017, 08:07 PM
I'm new around here and very impressed with the skill and craftsmanship in evidence.
Beautiful car
22-08-2017, 08:21 PM
(This post was last modified: 22-08-2017, 08:30 PM by SIngleSeater36.)
(22-08-2017, 05:24 PM)Derek Sheldon Wrote: Very nice , mind that exhaust. What sort of speed would you expect to get out of her. There you are one of the classic questions . What's it worth and how old is it. My grandad didn't learn to drive in one. The Thanks Derek, exhaust is due a good wrapping any day now! (22-08-2017, 06:01 PM)Duncan Grimmond Wrote: Very tidy, a lovely job. Thanks Duncan. (22-08-2017, 07:12 PM)Albert S Wrote: Excellent,well done... building from scratch is a considerable endeavour. Hi Albert, So many hours I cannot tell you. Lots of obstacles to overcome but it seems very worthwhile. The front axle is a 1950 design with an integral bearing / bushing assembly in it allowing the beam to twist a small amount. The headers are my design and creation but the back box is off a Harley, the exhaust note is perfect. Yes driven it, now adjusting a few parts, pedal box and prop shaft length and UJ's. The suspension worked perfectly. I am also going to fit a 4.3 ratio rear crown wheel and pinion to give the gears some more length. This will not be available till early October though. James (22-08-2017, 08:07 PM)John Penny Wrote: I'm new around here and very impressed with the skill and craftsmanship in evidence. Thanks John, for such a simple car it has absorbed so many hours and engineering time.
22-08-2017, 08:41 PM
I have enjoyed watching your progress on the Forum and on FB - a very purposeful looking car which sounds very sweet. Good luck with racing, and developing, it further.
22-08-2017, 08:47 PM
(This post was last modified: 22-08-2017, 08:51 PM by SIngleSeater36.)
A few engine shots.
(22-08-2017, 08:41 PM)Ruairidh Dunford Wrote: I have enjoyed watching your progress on the Forum and on FB - a very purposeful looking car which sounds very sweet. Good luck with racing, and developing, it further. Thanks Ruairidh, Its a mixture of mostly old as you can see and some new bits and pieces, not everyone's cup of tea but its running gear and chassis date back to the 1930s and I have tried to use all old bits when I can. Development will continue for many years no doubt! James
22-08-2017, 09:25 PM
Stunning, stunning car. Makes me realise how little I know and how limited my skills are!
22-08-2017, 09:58 PM
Hi James, A very well engineered Special
One Question How does the spring on the control rod the runs above the rear springs at the diff end Work. I fully understand if you would rather not explain. All the best for the first race Colin |
