Rivets on handbrake cover
I'm wondering what the name is of the rivets that hold the handbrake boot cover down? They appear to be a flat head and brass, but the underside has a hole in it like a pop rivet. The head has not hole, so like a solid rivet.
Erich in Mukilteo
Suggest they may be Bifurcated Rivets
Bifurcated rivets are split in two along the shank. These sound more like the type used for the brake shoes and clutch... and they are called semi-tubular rivets.
Do you have a picture, Eric? Fastenings can go under a variety of names.
Hi Erich
I would call them….. “Blind, flat head, hollow copper rivets”. But I’m no expert.
They should be fitted using a roll top rivet punch. However I’ve never managed to get the very expensive set of punches I bought to give a good finish and end up finishing the job with a flat punch.
Hi All,
Thank you all for the responses. I think Nick has it right. I hsve a tool somewhere that I think will set the back. Being brass, I won't have to use my 3X rivet gun, just a hammer and an anvil.
Erich in Mukilteo
