Ah... you lied to us... it wasn't a 25w map reading light at all... it was one of Anne's newfangled headlights... 1937 though? They must have borrowed a DeLorean, or stolen it from the GEC Hirst research centre... No wonder they look so furtive!
Well done though. I'd thought of doing the same but hadn't considered putting the tell-tale next to the blue plastic window of another gauge...
(28-11-2021, 01:14 AM)Nick Lettington Wrote: Ah... you lied to us... it wasn't a 25w map reading light at all... it was one of Anne's newfangled headlights... 1937 though? They must have borrowed a DeLorean, or stolen it from the GEC Hirst research centre... No wonder they look so furtive!
I used a tiny 6-volt LED (though a 12-volt might have been less startlingly bright) that, rather handily, just poked through a small hole in the blue plastic window of the fuel gauge. The wire was fastened using a cable tie to a convenience point.
The bulb used is a 3mm type, something like this -
On my RP, I have simply wired the dip switch so that , in the down position it is dipped and in the up position it is main. A quick feel of the switch tells me which beam I am on. However, on standard lamps, no one has flashed me if I forget to dip my lights yet!
28-11-2021, 11:46 AM (This post was last modified: 28-11-2021, 11:52 AM by Tony Griffiths.)
(28-11-2021, 09:21 AM)Mike Costigan Wrote: You need to do something with the speedo illumination, though
It does work - but hidden by the wheel in the pictures. I made the mistake of using bright-white LEDs behind the panel, so the light looks anything but authentic. I will change them - when the bulbs fail at 60,000 hours.....
My panel lights are also LED. It's nice to finally be able to read the gauges at night... one thing I find really odd is the glow in the bulbs when the battery is disconnected. I hope it's the capacitor in the distributor, not the car slowly disoving and generating its own electricity...
