When adjusting Ruby brakes with the semi-Girling system I have found it very useful to get all the wheels off the road using blocks to support the axles after jacking each end in turn. In this position you are better able to judge the effect of each adjuster by turning the appropriate wheel. If you start with two clicks taken up on the handbrake and adjust fronts first until just beginning to bite, then take up another notch on the handbrake and do the same at the back, then you will be somewhere near. But if the kingpins are badly shot the front brakes will not neccessarily behave ideally. it is essential that all cables move freely.
The wandering can be improved. The darting on certain contours due bump steer effects is something you adapt to as most on here instictively have. It will improve your driving skills generally! As above a light steering grip allows the wheel to move which absorbs some of the deflections.
Hopefully the kps will not be loose in the axle.....
Advice on here supercedes some in the original handbook; notably oil levels and hub greasing. Search should reveal.
Just thought I would take a qiuck look before going to work.. David!! Dam good effort at any time let alone at 10:30.... well past my bed time . That's something else i need to inspect..
I'm starting a list.
[Hopefully the kps will not be loose in the axle.....] Bob.. you know I've got to ask! What is the KPS, and how to check it loose or otherwise.
I would just like to say that I really appreciate everones help and responses, its very refreshing in the modern world we live in.
Anyway Time for work.
Regards
Col
My experience is that when the brakes are in good order on the semi-Girling system .75 to .8g can be achieved by pressing hard on the pedal.
When doing the king pins you might want to check if the faces of the stub axles are parallel and at 90 degrees to the kps axis..they may need grinding or cutting with a cutter and pilot if they are worn; likewise the top and bottom faces of the axle ends.
Your next saga may well be with the so called "hour glass" steering box and its internals .......see recent discussions.
Welcome to the world of sevens......I used to do the every other weekend trip of 200 miles each way home then back in my MK1 ruby......but then I was young and in love. The drive was not scary.....just a little boring at times.......60 + achieved quite often.
Good evening good people of the forum.
John I had a look and the plate you mentioned it was there ARQ32185 thought to look for the engine number M242980. I had the brake drums off the front and the shoes and drums look in very good shape.
Dennis with regards to the what you were saying about the kingpins, stub axles and steering box, I think your right as the wheels will push to the right but not to the left. At the steering wheel moving from left to right there is a very subtle kind of stiffness from full lock to the center.
