A7CA drawings
Can anyone tell me how to get high-res drawings from the A7CA website? I'm sure I have done it before but now if I open any of the chassis drawings they are too pixelated to read the dimensions. Am I right in thinking they are held in two different places on the site?
I take it you have looked here, Peter?
http://archive.a7ca.org/collections/technical-drawings/
If these are not of the required resolution, I do have them all at a higher res (I have had them all re-imaged) but there has been no time to upload them what with all the work that has been going on for the Centenary.
If the drawing you require is not at the resolution you need on the site, then drop me a mail at archivist@a7ca.org stating which drawing you are looking for and I'll see what I can do...
Hugh
Thank you Hugh that's most helpful, I appreciate the time these things take. Yes that was where I had looked
I will check which one it is I require and email you tomorrow.
Hi,
Does the archive have a dimensional drawing of the block face?
Thanks
David
Everything we have is published, David...
hth...
