17-09-2021, 02:35 PM
Okay thanks Howard, so for Chummies the sidelight setting for the front facing lights is effectively the same as dipped beam?
Wiring from scratch
17-09-2021, 03:08 PM
Hi Rupert
Yep…..Although the main beam can hardly be called that…Bit like a couple of candles lighting the way . Cheers Howard
12-10-2021, 08:57 PM
So my next question is whether or not there's a view on tinning the end of wires that are going into screw/threaded terminals? My Box saloon appears to have the ends tinned, but I've seen some conflicting information on whether this can actually be detrimental over time as it can crack.
12-10-2021, 09:03 PM
(12-10-2021, 08:57 PM)RupertW Wrote: So my next question is whether or not there's a view on tinning the end of wires that are going into screw/threaded terminals? My Box saloon appears to have the ends tinned, but I've seen some conflicting information on whether this can actually be detrimental over time as it can crack. I've tinned the ends, and done it without tinning. Prefer it without, otherwise solder runs into the cable and the wire can easily break at the end of the soldered bit. I now put bare wire into a threaded terminal, tighten the screw, then put on a drop or two of WD40 to prevent corrosion. |
