06-10-2021, 03:23 PM
Hi
We may be able to supply new lever
ARP ltd tel 01202 625242
Lucas SM5 switch panel spare parts
Hi
We may be able to supply new lever ARP ltd tel 01202 625242
07-10-2021, 08:27 AM
bump to the previous question in #10. It's one of those things about the forum. You try to keep threads full of the same sort of information so it becomes a good resource, but new readers do tend to go to the top of a thread rather than the last post?
12-10-2021, 11:23 AM
(06-10-2021, 10:28 AM)JonE Wrote: Just re-assembling and I could have sworn there was a good how-to on one of the owners clubs. Cornwall just concentrates on the lettering for the switchpanel. Any suggestions? Hi Jon, I think the switch panel I started the thread with is probably the fourth ( and grottiest) one I've rebuilt. I don't remember there being any washers around any part of the knobs, that's not to say they weren't there from the factory. The Lucas metal protective rear cover for the SM5 wiring seems to be a lot rarer than hens' teeth. The asymmetric wings on the brass wipers provide the 'stop' at the ends of the knobs rotational travel when they're inserted in the right way round/correct side. If you get that wrong on assembly the first time it should be obvious as the 'sweep' will be wrong.
12-10-2021, 01:32 PM
I doubt if the rear protective panel was fitted to SM5 panels destined for Austin 7’s as a cost saving measure.
12-10-2021, 02:28 PM
12-10-2021, 07:40 PM
12-10-2021, 10:19 PM
(This post was last modified: 12-10-2021, 10:20 PM by Tony Press.)
(12-10-2021, 02:28 PM)Parazine Wrote:(12-10-2021, 01:32 PM)Stuart Joseph Wrote: I doubt if the rear protective panel was fitted to SM5 panels destined for Austin 7’s as a cost saving measure. I don't think there is room for the rear cover between the dashboard and the petrol tank in the early cars. |
