08-10-2021, 07:26 PM
I am looking for a vacuum wiper motor for a 29' chummy. the cylindrical one is the one i think is supposed to be on it. i also need the wiper arm to go with it.
wiper motor
10-10-2021, 10:43 AM
For a used cylindrical vacuum wiper motor contact Tony Betts at 7 County Austins
http://www.7ca.co.uk For a new wiper arm, wiper blade, rubber retaining peg and vacuum wiper hose contact David Cochrane at A7 Components - under the section 'Windscreen' see part numbers: 2H7784, BW909, 2H7788b or 2H7788c and BW908 (David Cochrane will advise you on which items you require for your particular 1929 chummy based on its chassis number / car number etc). https://www.a7c.co.uk/spares.php#bodywork The following link gives details of where to find the various numbers on your car if you haven't already found them: http://a7ca.org/downloads/QuoteThisNumber.pdf |
