23-09-2021, 09:15 PM
Good evening. I am trying to establish the correct value of the two fuses in the cutout/fuse box. Currently (no pun intended) the Auxiliary fuse is 35Amp the field fuse 8Amp. What value would they have been originally?
Personally I always advocate fitting individual fuses and relays for each circuit which can be discretly mounted.
Regards from the creative county - Staffordshire
