Machined core plugs
Although not original, I thought I would show you the threaded core plugs I made for my '29 cylinder block.
The correct plugs are the domed disc plugs you insert and expand with a dent in the center but sometime in the past  the previous owner had elected to tap these holes for 5/8" BPT plugs which had to be drilled out in order to gain access to the corrosion plugged cooling channels in the block. I got about a cup of rust out of the block.
I modified two modern plugs to resemble the large core plugs already in the block so that they would not look out of place.
Fiddly work but I am pleased at how they turned out.
Stephen
They look great
Yes, very nice work.
(18-02-2018, 07:16 PM)steve davidson Wrote: They look great
Hi Steve, nice work.This is a vintage block and had screw in plugs.Later blocks have the steel disc core plugs.
They look smart, but I'm wondering how you intend getting a good seal. Are you going to rely on the fibre washer alone, or something else?
I 'm thinking the threads look to be parallel rather than taper, and the face of the block doesn't look like a perfect surface on which to to get a seal.
Yes I do think a thread sealant of some description might be a good idea - something with a low shear strength so it can be undone again in the future.
(18-02-2018, 06:12 PM)Steve Bryant Wrote: Although not original, I thought I would show you the threaded core plugs I made for my '29 cylinder block.
Stephen
Nice job- originally there were no plugs fitted here and this modification is very useful in keeping the block clean in this area.
Mine are fitted with square  head taper plugs - hopefully easier to remove.
Cheers Tony.
(18-02-2018, 08:32 PM)Colin Wilks Wrote: They look smart, but I'm wondering how you intend getting a good seal. Are you going to rely on the fibre washer alone, or something else?
Hi Colin,
i can assure you that the treads are tapered. It took me ages to find two  5/8 BPT x 19 (I  think) TPI plugs locally.   There will be thread seal applied to the threads on installation. So the fiber washer is a secondary seal. The sealing surface on the block is better than it looks too by the way.
Stephen
Stephen
Cheers Tony.
Tony, surprised at you saying that, I have seen numerous blocks with 2 core plugs at each end
Stephen
Cheers Tony.
Only two (front and back) Cylinder End Plugs BC 14 (with washers BC15) ever listed for the Cylinder monobloc.
The extra plugs are a popular modification
Cheers, Tony.
