07-09-2021, 10:09 PM
(This post was last modified: 07-09-2021, 10:50 PM by Dennis Nicholas.)
(06-09-2021, 07:54 PM)andrew34ruby Wrote:(06-09-2021, 11:15 AM)Dennis Nicholas Wrote: My Nippy special is one of those with a BMC A engine. Started as a wreck with no engine so fitted a 948 cc BMC A engine and gearbox. Piston broke in that at 70,000+ miles including daily transport and MCC classic Trials so now fitting BMC A+ 1275 cc (1300) mated (by a kit) to a Toyota T50 box. Same dimension and easy swap with modified box mount.Dennis, I appreciate you are now fitting a 1275 A+ engine, but what was the Nippy like on the road with a 950 A series engine? And going up hills?
Dennis
quite fast when required. No problem accelerating up hills.....great fun up Porlock passing most moderns in safety as occasion allowed. On one MCC trial near Teignmouth hill started in farm yard then through gate immediately unseen onto steep grassy uphill.....I should have stayed in 1st through gate but for some reason went to 2nd through gate and startled to see steep hill and revs dropped to about 400 RPM ...to change down to 1 would have lost grip and no further forward motion so stayed in 2 and foot to floor...chugged all way up and could hear spectators "thats how an A7 should sound and go"!!!!! great cheers as I made it over top much to my relief. A bit scarey to drive on its 19 inch between sections when pushing on to make up lost time.....like the long run down to Blue Hills Mines. Normally on road used 15" and nice and stable.......good on 16" but could not get tyres a good few years ago. 15'...thank you 2CV etc. I am always mindful of the power being put through the back axle...the later 1939 with the longer taper thicker half-shafts.....so no silly high revs and drop clutch in quick.
1275 only going in after 948 piston demise and because cheap at time and from a crashed 40,000 miles car (Ital?) Has heater too, now upgraded to a 2 speed blower heater from a Mini.......global warming??....Devon will be warmer when I get back on the road again
Dennis
(06-09-2021, 10:22 PM)Parazine Wrote:Ah, I am all fruity here.....Apple MackBook and Apple Mini with Apple app "Photos" and have app "Fotor Photo Editor".....but without written instructions finding it difficult to do any photo editing (not to mention age making brainwork difficult). Edited pictures seem to get saved "somewhere" but with a different file ending. I just don't have time to spend hours trying to learn special handling processes only to forget how again within a few days!!(06-09-2021, 12:18 PM)Dennis Nicholas Wrote: Is it possible to modify "in house" picture posting to accept larger files? Modern digital camera files even on modest lower settings are probably larger than the "acceptable limits" Certainly some of mine seem to be. I have no problems posting any size file on another car club forum I post on.
Dennis
If you use Windows 10, open the photo using the built in "Photos" app. Right click in the picture then choose "Resize", just below half way down the menu. You get the choice of Small, Medium, Large or Custom. Save the resized file somewhere in your file structure where you can find it and then upload the reduced file. I choose Small or Medium, reduces several MB files to a few tens or hundred kB.
I was trying to put up the front view of me going up Bamford Clough with caption of cars details beneath.
I could email someone the relevant photo if they could trim it down and put it on here? Get details tells me it is 6MB.
Dennis
