30-08-2021, 10:53 PM
Replicating Bakelite Colour
31-08-2021, 04:39 PM
I repaired a black plastic car badge, didnt know what to use as a die, and google didnt help much. I used 5 min araldite (clear), with a dab of normal oil based black paint. Didn't take a lot, went as black as coal. Worked perfectly.
Thank you, Hedd.
My current thinking is to try and dye some fine sawdust to the right colour and then mix that into a clear resin. I shall be using some for another project shortly, so can experiment with any leftovers, using silicon sweet moulds for the shape. I might still need some colour in the resin, but I hope that the wood dust will give a semblance of the original look of Bakelite, as you suggest. Regards, Jamie.
04-09-2021, 10:20 AM
Try MDF powder. It goes surprisingly dark when mixed with resin.
04-09-2021, 04:27 PM
Just don't breathe in while powdering your MDF! Highly toxic...
05-09-2021, 09:38 AM
(04-09-2021, 10:20 AM)Bruce Nicholls Wrote: Try MDF powder. It goes surprisingly dark when mixed with resin. I shall try that. I have made a couple of pieces using a silicon mould for making sugar paste cake decorations. I mixed a fairly dark sawdust into a resin mix. The result was very encouraging, although it was a too dark for my liking, tending towards black too much. It did not help that I got the ratios wrong and the resin has set like a piece of warm toffee. Regards, Jamie.
05-09-2021, 10:29 AM
Hmmm! Did you taste it Jamie?
05-09-2021, 11:34 AM
