08-08-2021, 02:40 PM
(This post was last modified: 08-08-2021, 03:38 PM by Tony Griffiths.)
As Mike spent a good many years in the printing trade, he knows his P & Q fonts. How does this rate?
License plate mounting plate
08-08-2021, 03:36 PM
Typical hand-painted style appropriate to the period; the P and L are perhaps a little wide, they look to be more than the regulation 2 1/2", whilst the gap between them is less than the appropriate 1/2"!
Signed: Pedants Anonymous
08-08-2021, 04:03 PM
08-08-2021, 06:49 PM
Found a photo on the net with the same arrangement Just need to fabricate the support and buy the mounting plate from a vendor. Attachment is what I found on the net.
08-08-2021, 07:53 PM
Hi Sneezer
That’s my 1930 RK. I am not sure if the RP has the same mounting as the spare wheel is a little higher on the rear of the car. I am sure others will advise. Here is a picture with the number plate painted. Just so Mike Tony and Chris can tut tut and suck their teeth at the Charles Wright font . Cheers Howard
08-08-2021, 08:50 PM
All that was visible to me was the lower section. Your photo shows the obvious difference between my cars backend and yours. Any comments on what style of taillights I should install will be appreciated. No big rush as I am not picking the car up until Sept 3rd or 4th.
08-08-2021, 09:08 PM
That looks pretty good to me, Howard - the '2' looks to have a more rounded top than Charles Wright, and all the better for it! Incidentally, having checked, if anyone does want to use the C W font as a guide, I suggest they use C W Bold, which does have a more rounded shape.
08-08-2021, 09:26 PM
Hi Mike
Thanks for the kind words. The font was bold so that must have helped. Cheers Howard
09-08-2021, 02:56 AM
Incidentally the mounting strap on cars without rear tank differ.
09-08-2021, 09:48 AM
At the risk of confusing things further, here's my RP, it originally had a number plate extended on one side for a D shaped lamp, but as I had a pair of brand new Chummy style lamps in stock, I used those I chose my own font as I wanted something a little bolder...but I think it looks okay, after all it is for driving, not for showing...
