05-08-2021, 12:59 PM
Hello,
I'm new here and new to Sevens. I bought a 1928 Chummy earlier this year and am enjoying getting to know it. It starts readily on the handle (its previous owner changed from mag to coil ignition) but the starter motor is feeble and barely turns over despite a good battery, so I've removed it and cleaned up the commutator and brushes as per the advice in the Woodrow manual. But refitting the motor is not proving to be as straightforward as its removal!
The nearside set screw that secures the starter to the crankcase will engage a couple of threads then bind - I don't want to force it and risk stripping the crankcase threads. The set screw will go in and out quite happily without the motor, and the offside one engages fully with the motor in situ. But as soon as the motor is on, it won't tighten (or rather, it begins to get tight too soon) I've tried fitting it without the backplate as that presses up onto the bulkhead, but it's no better. The hole in the bulkhead for the nut on the back of the motor didn't line up well so I've enlarged it slightly - still no good...
Is this a Chummy thing, or is it a case of 'the nut behind the spanner'? Any advice on this would be received gratefully!
Neil Stanford
York
Neil Stanford
York
