STEERING BOX LARGE END SCREW ??
Evening , can someone take a look at the picture attached and tell me if this end screw is removable, although I only need the end brass steering rod retainer.
Many thanks.
RPM
You need to tighten the column down hard to lock the retainer so you can release the nut. Terry.
Thank You Terry, so glad I asked, would never have known. Simple when you know how.
Regards Rob. RPM
