Rear universal joint socket
Oh, such a relief on the over-run
What a well cared for joint should look like  Big Grin
Well, that was a value-for-money-per-mile achievement....
That’s going to take some pretty imaginative engineering to return to serviceable condition!
A new Hardy Spicer prop shaft might be more practical than repairing the old?
Russlin.
Maybe I just read the wrong books but there seems so little written about these joints and their repair/ maintenance.
Or is there simply nothing to write?
Failed Under Constant Kineticism + Expert Driving....
There was a lot of known about these in the 1960s / 1970s and part swapping for better pins blocks and housings was usual.
I even found a pair of good blocks and a pin in a charity shop !!!  They were in a box of Meccano bits.
The pins and blocks are available, of course: https://www.theaustinsevenworkshop.com/p...and-blocks - but you'll need to source a serviceable housing
A very common sight for those who use their cars, a by-product of enjoying them.
Keep on driving Henry!
