05-02-2018, 06:27 PM
Hi everyone.
I have a Lucas SM5 switch panel with a broken wound resistor wire to the ignition warning light.
I'm anxious to keep the original bulb to work from the 6 volt system.
Is there anyone who could repair this by rewinding the resistor ?
Otherwise could someone with knowledge suggest a way that I might be able to repair it by using a diode or something similar ? I have to add that I am not particularly good with electrical problems or a soldering iron so if someone could carry out the repair that would be the best option. Maybe you could let me know together with an estimated cost please.
Thank you in advance for any helpful replies.
Pete
Pete
