coupled brakes in 1926?
You are very welcome - good luck with project.
Is this the accessory coupling bit?
(05-02-2018, 06:42 PM)Rob Hanauer Wrote: Is this the accessory coupling bit?
Hello Rob,
That’s interesting, I guess there are 3 vital questions;
What is the internal diameter of the clamp?
What is the Center to Center measurement, clamp to hole in the lever?
If the first two questions check out, then would you like to sell it?
Regards, Mark
That looks very like a Bodelo arm.
Cheers, Tony.
