Andrew, I like the idea of using a peep mirror as a door mirror, is it big enough and do you use a flat or convex one?
    Refurbished an RN sunshine roof today.
(05-05-2021, 04:12 PM)Ivor Hawkins Wrote: Andrew, I like the idea of using a peep mirror as a door mirror, is it big enough and do you use a flat or convex one?
What is a 'peep mirror'?  Anyway, that mirror is flat, not convex, and really is pretty useless. Same size in convex might be ok, I'm not sure. It doesn't much bother me, I learned to drive in an era before door mirrors.
(05-05-2021, 08:35 PM)Dave Mann Wrote: Refurbished an RN sunshine roof today.
Looks good for another 89 years....
Today I had a small window of opportunity to get greasy whilst the others watched the Sewing Bakeoff. I decided to take a quick look at the radiator tap on the ORT whilst it is sitting on the garage floor. As l had dismantled and cleaned it a year or five ago I was annoyed that it had always dripped a little. Having a spare radiator in perilous condition, I took the tap, eased it apart, cleaned it, made a new spring and found some nice brass washers. As I unscrewed the drippy old tap I dislodged a smear of epoxy putty from the edge of the tank, with tell-tale crystals on the edges... what joy. The drip was from a crack in the base of the radiator all along... so that's a half hour wasted that I won't be getting back, and another job to add to the list before the wedding in June...
Modify the spindle to take flat-head, countersunk screws - and then file the edges down. Here's one I did earlier...
(05-05-2021, 11:32 PM)Tony Griffiths Wrote: Modify the spindle to take flat-head, countersunk screws - and then file the edges down. Here's one I did earlier...
Thanks Tony
I’ve countersunk the holes, filed down the screw heads and cut off the tails. I will Loctite them in when finished. The spindle is only 1/4” so I didn’t want to go too wild with the countersinking.
What you have there is known as a peep mirror and they are usually mounted on the top of the door. like you I learned to drive before door mirrors and being a motor cyclist, I look over my shoulder anyway, but it would have been nice to learn that the mirror actually worked!
Hi all, my first post in this thread.  Thankfully lockdown has lifted enough for me to get back to my fathers to do more work on the Austin.  Finding a gap in the weather recently we managed to get the exterior primed in a high build cellulose primer.
After priming it, i immediately regretted not removing those beadings between the rear 3/4 panel and the arches.  They aren't fitted well and masking them will be a nightmare.  What to do????
All i can say is it looks fantastic in matt Grey!  I remember seeing and speaking to the owner of a beautiful grey model at Beaulieu a few years ago so it immediately sent me back.  I hope painting it Blue doesn't make me start getting envious!
From what I can see it looks good. When I had my Ruby re sprayed a few years ago I removed the front and rear wings together with the running boards. This made things easier and there was no need to mask up as these were to be pained a different colour.
John Mason
Users browsing this thread: GM6VXB, 25 Guest(s)
