26-03-2021, 08:21 PM
Can anyone tell me the Diameter of the spokes fitted to a 1933 wheel . I have measured one I have and it looks like .187 inch. (or ~ 11 Stubs steel Wire Gage)
Spoke Diameter
26-03-2021, 08:57 PM
The original spokes for wheels with stainless cap were 7 gauge (Imp SWG).176 inches but 6 gauge.192 inches for the thread, which is a Cylce thread not of whitworth or UNF form (and not 3/16 UNF. or 10.32! )
I gather replacement spokes are of one gauge (and look thick). Does anyone know if nipples with genuine original thread are avail and where? And where a 6 Gauge cycle thread tap and/or die might be obtained? In my experience the Seven spokes are very robust.
26-03-2021, 10:22 PM
Spokes are generally made with a rolled thread, leaving the outer edge of the thread larger than the plain spoke and the inner edge less indented than a died thread would be, resulting in a larger minimum cross section at the thread with higher tensile strength. For this reason putting threads on spokes with a die is inadvisable. It is always best to use a nipple of the correct size for the spoke.
27-03-2021, 10:46 AM
Richard Brothers in Cardiff Wales would be a good place to start. An old company with excellent parts and service and a manufacturer of most of its products.
I agree completely with rolled thread spokes being a must. Also that Austin Spokes (original) were excellent quality- I think Rubery Owen were the manufacturers of the wheels you have Cheers Steve Hainsworth
27-03-2021, 11:37 PM
on my Remax spoke gauge for Austin seven, for 32 - 33 7 standard wire gauge, short 5 5/16" long 7 27/32"
for 34 same spokes but the short spoke is 5/8 longer i.e. 5 15/16". Length is measured from inside the bend. In 36 they change again. |
