Unregistered Sports Chassis & DVLA
I would say its a very good kit of parts for a special to get into Austin Seven Racing. Might not be VSCC accepted though with Big Seven front and Back axles.
It has all the good bits you need for Bert Hadley championship. Nobody from DVLA would be able to tell its not all from the same car.
Thank you Tony for feeding an informed discussion. Certainly a Bert Hadley possiblity. I haven’t quite worked out what will be eligible for the VSCC’s new Specials class in racing.
thank you steve.
i always found the VSCC a bit like the DVLA?
they both tend to have guidelines not rules.
that way.
they both let you build it, and then tell you if you got it right or not?
tony.
