Speedo
Could someone kindly confirm which model(s) this might have been fitted to?
.jpg   speedo.jpg (Size: 14.91 KB / Downloads: 293)
I think it's late Chummy up to RN (3 speed) Is that right?
tia..
    It's not off an RN which uses a PA speedo.
Hi Hugh,
As long as I  know, Chummies up to 1929 had a Speedo bezel with four nuts and a  90º drive outlet. Speedo model PA.
The one shown  is a PN and may be have a 45º drive outlet.
Cordially,
Bert
Later (November '27 on) Chummies and saloons also use a PA.
I think the photo shows an early Austin 10 speedometer.
If I remember correctly, my 1934 Austin 10 was fitted with a PN speedo.
Ah, so not 7 then...
Thanks all...
Would the boat tail 2 seater tourer of 29/30 have that speedo, considering that there was an arc shaped cutout in the dashboard to clear the gearlever/ handbrake? So rather than the cable coming down vertically to the speedo take off on the gearbox, the cable was offset. I may be entirely wrong!
Hi
If you are thinking of using it in a Seven the gearing may be wrong.  They are not easy to recalibrate unless you use a gearbox on the drive cable.
Actually, seem like this is a topic that was briefly touched on before. A PN is rated at 2240 TPM, it would seem and the Austin 10 connection was mentioned then...
https://www.austinsevenfriends.co.uk/for...p?tid=2231
should have searched first. Sorry...
