A7 Underslung chassis or Drop Frame
Dear Each and All
 I recently came across some letters, written in1932,  from A.P. Compton & Co. Ltd., of Arrow Coachworks, Boston Road, Hanwell, W7. to one of their customers, Norton Bracey Esq., of Weybridge.
In the letter of 21st March 1932, A.P Compton refers to Mr Bracey's interest in "the Arrow 4-seater as fitted to the super sports underslung chassis  and that you would like to inspect one of these cars when we have one available.".  The letter goes on "We would advise you that we only build this body to the Austin 7 underslung chassis to special order and as it is not a production job with us it is rather difficult to advise you when you may inspect one."
In the letter of 1st April 1932, from A.P. Compton, which is confirming Mr Bracey's impending visit to the Arrow Coachworks, the following is the final paragraph - "We would mention that if you manage to get here between 11.0 and 12.0 noon you would be able to see a Arrow Foursome body mounted on the same type of chassis in which you are interested, namely the Austin 7 underslung sports, as we have one which has been returned for fitting some extras and the client is collecting it tomorrow about midday."
In a letter from Messrs. Hattons Ltd., 665/667 Lord Street, Southport, to A.P Compton & Co. Ltd., they are really enthusiastic about the "Arrow Sports four seater on the drop frame Austin 7 h.p. unsupercharged chassis as supplied to their client".
None of these particular version of the Austin 7 Arrow Sports Foursome now exist.
I am really not sure what a "drop frame Austin 7 unsupercharged chassis”  is, or "an Austin 7 underslung chassis” - can anyone please explain what these chassis were and what Austin 7 models they were used for.
Regards
Jim Blacklock
Austin 7 Arrow Register Registrar.
Sounds like a description of a normal lowered sports chassis.
Mr Arthur P Compton was involved in several company's producing sports bodies.  Compton & Hermon, Compton Sons & Terry, A P Compton,  Compton's and Arrow Coachwork's that made bodies for Austin 7, Jowett, Standard,  Morris, Wolsely, Hillman, Rootes, Crossley, Vauxhall and Ford, He was also at one time the designer and manager at Jarvis that later after his departure became Abbey Coachworks. In 1932 the Austin Arrow 2 seater sold for £152-10, Austin Arrow foursome £155 and the Austin Arrow Coupe £163-5. The main distriduters for Austin Arrows was Normand Garages later replaced by H A Saunders, when Arrow went out of business in 1934 the remaining Austin Arrow  bodies were sent to Whitttigham and Mitchel to be finished and the Hanwell works was taken over by Coachcraft.
(20-01-2018, 01:10 PM)Jim Blacklock Wrote: Dear Each and All
Regards
Jim Blacklock
I cannot comment on the Austin/Arrow part of the enquiry, however I can add something about Mr Norton Bracey. At about this time he purchased a Wolseley Hornet Special. It seems his family had connections through the motor trade to Wolseley. The car was raced and trailed extensively over a few years and repairs, when required were often underwritten by Wolseley or their Agent. A few years ago the car was discovered by the WHS Club President, rebuilt and I was fortunate to be present on one of its first outings at the VSCC Goodwood Sprint, when Norton Bracey's daughter attended, bringing with her the quite large collection of trophies won by her father in the car. I will locate the photo and post it later. I may be able to put you in touch with her if you feel the enquiry might be productive.
I would suggest that 'drop frame' and 'underslung' chassis both refer to the standard Austin Sports chassis - Ulster and later the Type 65; 'drop frame' because the lower springs 'drop' the frame, and 'underslung' because the radium arms are located 'under' the front axle. Both terms were in vogue at the time and doubtless Comptons wanted a slice of the action, even if the Austin chassis was technically neither!
(20-01-2018, 04:52 PM)Mike Costigan Wrote: I would suggest that 'drop frame' and 'underslung' chassis both refer to the standard Austin Sports chassis - Ulster and later the Type 65; 'drop frame' because the lower springs 'drop' the frame, and 'underslung' because the radium arms are located 'under' the front axle. Both terms were in vogue at the time and doubtless Comptons wanted a slice of the action, even if the Austin chassis was technically neither!
I agree with Michael. The article in the Dec. '34 "Light Car" by L M Williams, entitled "Underslinging an Austin Seven", in essence describes conversion to Austin Sports layout. While it is a rather casual use of the term I think that, in this context, "underslung" is synonymous with "lowered".
Regards,
Stuart
Not the best photo to illustrate, but I may find another, if nobody else does...
I suppose fitting a flattened rear spring on top of the chassis rail as some racing Austins have would be the nearest thing to underslinging a chassis.
Regards
Jim Blacklock
Dear Jack,
Would this Wolseley Hornet Special be Reg# GY713??  I ask because it is the only one that I have found, during my search for any remaining Arrows.  If this car is connected the the letters of March 1932, then that would be rather amazing.  Thank you for your response. Cheers, Jim
Regards
Jim Blacklock
Dear Jack,
Hello Jim,
No the reg is PJ 6010, If you PM me the whole number I will let you know which car GY is
Regards Jack
