Car type: RP Deluxe Saloon 1933
(18-01-2018, 11:03 PM)Phil Kingdom Wrote: Hi Roger, I think we met at Tavernspite a couple of months back, My friend recently fitted a battery isolator that fits directly on to the battery terminal though I cant remember where he said he got it but it is probably the neatest way of doing it rather than the larger key type isolator that will require further wiring
Thank you for all the suggestions I have sent for one of the “Green Knob” type.
No Phil it was not me I am still reconstructing my A7 RP so do not stray too far from the garage!
Roger
Hi Roger,
The nice things about this site is how we manage to get sidetracked with fresh ideas slightly 'off topic,' although my spelling of fuel must have caused some mirth! Anyway, just where you fit your switch is your choice, just somewhere that is not obvious to children etc. at rallies that insist on moving anything movable and pressing the horn button with gusto. Plus of course foiling those who have a sinister intention, it being far easier to drive than push. I fitted my isolator after finding out that the forward facing starter motor is always live, even with the ignition off - bit of a shock to the old ticker were that!
Don't forget to use good quality starter cable throughout with good soldered joints if using a 'fit anywhere' isolator.
Have fun, Peter.
I too have a green knob (Don't Google that!) with original Negative earth. Without going & checking I am almost certain it is fitted to the earth terminal. I am not good with electrics, but I am sure that is how it is supposed to be. The photo looks as if that is the power cable....?
