Dashboard 1932 AG
I have removed the four large headed slotted screws & their nuts etc from the dashboard, but it is unwilling to come away. OK the oil pressure gauge & sundry other bits are still connected, but there appears to be something I have missed (in the area of the middle of the dash) as it is firmly attached to something![Image: confused.png]
The four bolts are the only means of affixing the panel; maybe it's stuck with layers of paint?
[Image: 007.jpg]
Try removing the the oil pressure gauge pipe - this often retains the dash panel.
(18-01-2018, 10:43 AM)Ruairidh Dunford Wrote: Try removing the the oil pressure gauge pipe - this often retains the dash panel.
Thanks for that.
I would like my dash panel to look a bit more like yours and I do have to remove it to do a bit of gentle fettling and I don't want to get it any more out of shape by mistreating it!
D
