Reading this thread reminds me of my ignorance about the various cylinder heads. Is the T&T head the same as the Dave Dye head (they look very similar)? It seems strange that the pictures of actual heads differ from the Ricardo patent drawing, in having restricted space over the inlet valve rather than the exhaust. Has anyone come across a head made in the style of the Ricardo drawing? Do any exist in this form? I have always used standard '37 type Austin heads, but I have occasionally wondered if the right aluminium head with its different design could be better, but if so which one?
May I suggest you contact Ricardo PLC at Bridge Works, Shoreham by Sea, they have a very extensive library on Harry's work,so should have the patent number there.
03-01-2021, 10:11 PM (This post was last modified: 03-01-2021, 10:15 PM by Austin in the Shed.
Edit Reason: add content
I don't claim to understand the tech in the patent documents but surely to "Create turbulence in the charge" would need the step on the inlet side as to cause turbulence as the gas passes over the step?
Did Ricardo get Thompson and Taylor to produce the heads,or did T and T produce them as their own venture ?
Hi Dave, I have 2 of your heads and perfectly happy with them but can now see they are not what is shown in the patent drawing. The T&T ones are obviously not in accord with the patent.
Turbulence, or squish can be produced by having a very tight clearance between the piston crown
and the flat portion of the head, this head has that capability. Squish clearance no more than .020”.
The interesting thing about this is T&T/ Ricardo heads clearly work. There’s loads of dynamometer results to prove that. Now, apparently Harry Ricardo was not the worlds best at publishing test results. I wonder if something caused him to change his mind. I really can’t believe it’s a mistake.
Alan , I've just dusted down my 1931 copy of Ricardo's ' The Internal Combustion Engine ' . A complete chapter is devoted to
' Influence of form of Combustion Chamber ' and the ' Shock Absorber ' Head as he called it is detailed , with test results etc., .
The pocket can be over either the inlet or exhaust valve and the spark plug over either valve , depending on what rate of burning you want to achieve. He also states that ' although the sparking plug is no longer centrally situated , the 'Shock Absorber ' type of head is very slightly better than the ordinary turbulent head '
Personally I think the very similar Whatmough - Hewitt patent combustion chamber is an improved design due to the chamber shape.
As I run one of each type of head I'm not too biased .
I will bring the book along at the first convenient Bert Hadley .
Geoff.,
