Hi Geoff
Great to have another post on your thread. What a contrast between the last two posts. Too hot to work in and too cold to work in!
I’m confined to work in my garage despite the fact that the next “urgent” job is spring removal on the RK. The RK sits under a lean to canopy so basically it’s outside! I’m building up enough courage to swap the cars around but as I’m half way through spring removal the RK is minus a rear axle at the moment!
Keep on keeping safe and do post some photos of the con rod balancing!
Season’s greetings
28-12-2020, 06:52 PM
(This post was last modified: 29-12-2020, 07:35 AM by bob46320.
Edit Reason: spelling
Are you making them or weighing them?. There must be an aeroplane somewhere, flying around with a big hole in it!
29-12-2020, 10:45 PM
(This post was last modified: 29-12-2020, 10:47 PM by Geoff Halstead.)
PS
No aircraft have been mutilated in any way or fashion :-)
Geoff - Bedtime having finished reading ‘Night Probe’
04-08-2021, 10:35 PM
(This post was last modified: 04-08-2021, 10:38 PM by Geoff Halstead.)
Since my last post things went south again due to tablets and my stupidity ?
Decided to spend more time in the Workshop using my machine tools in making tools, as I’ve been ignoring them for too long.
That time had the desired effect in getting my enthusiasm back to doing something worthwhile on the Ruby, until:
Mid-June I amputated the tip of my left thumb including a bit of bone & ripping the nail cleanly off/out, by placing it in the hinge side of bungalow front door jam, then attempting to close said door!!
How STUPID can one get⁉️
Plastic surgery that needed extra bone removal to allow skin to cover the now shorter thumb.
It is now healing quite well, with nail and thumb tip now half length.
Thank goodness it wasn’t the right thumb!
Doing buttons up needs a completely new approach, as is holding things.
Surgeon said 6-8weeks for nail to grow back and 6months for tip to heal.
Workshop time it is for the duration as I dare not try anything on the Ruby for fear of banging the tip that is still rather sensitive.
Talk about being in the Wars
Geoff - Is something/someone trying to tell me something?
PS.
I won’t post photos as they are not for the faint hearted??
I wondered what had happened, a lot of us have been there Geoff, both my daughter and myself when i was her age however both were done in wooden gates so not so severe damage done. hope it heals quickly.
Hi Geoff.
Me too. Put a hacksaw through my left index finger a few weeks ago. Luckily the injury was not as bad as yours and the local A & E sorted me out very quickly.
Really looking forward to your thread resuming!
Very frustrating for you Geoff and I'm missing your Ruby progress posts. In my youth I lost the end of my right index finger on a circular saw. It took a good few months but most of the sensation eventually returned and it is perfectly useable. In the interim my party trick was learning to tie my shoelaces with one hand!
