16-12-2020, 09:26 PM
I think and hope I've my brakes set up having had the car up on axle stands. Even the fronts operate before the rears!.
One usual thing the front brake binds on full lock, no surprise there, now I seem to remember a thread where some one had drilled a hole in the back plate and attached a spring from there to the brake lever so it fully released, if i pull the brake lever about 5mm more it releases the brake. Has anybody done that on here ?
