Grabbing Brake.
Here’s a silly problem for the cognoscenti. I have recently refined the front brakes on my RP and now find that, if I have left the car idle for a couple of days, the offside front brake grabs on initial application and does not release unless I reverse a foot or two. After a couple of applications, it behaves itself and doesn’t do it again until I have left the car for a day or two. It appears that the leading shoe (I.e. the rearmost one) is wrapping on. I have made sure that the shoes and cam mechanism is not sticking and tried swapping the drums over from side to side. All to no avail. I have done less that 400 miles since the redline, so is it a problem that might go away as the brakes bed in, or should I be looking for a more immediate problem?
On the road, the brakes are fine, pulling up square even on a emergency application.
Any thoughts?
Have you filed the ends of the lining to a shallow angle?
I find the ends tend to sit up and snag, when new, doing above helps.
Are you parking the car up with the handbrake on?
Thank you Ruairidh and Bruce. In answer to your questions, no I haven’t chamfered the ends of the linings. I never do. And no, I always leave the handbrake off when the car is in the garage. Do you think chamfering the leading edge would help?
I do.
Thanks, Ruairidh, I shall try that this weekend and see if it cures the problem.
+1 for chamfering the ends of all the linings !!
Aye
Greig
Me too.
Thanks all for the advice. Strangely enough, when I was an apprentice, (When dinosaurs roamed West Wales) I was told that chamfering the shoes was bad practice. I never found out why this was.
Probably contained Asbestos in those days.
