The Fuelflow ECCO LM102 is the best option.
it is a diaphragm pump design expressly for SUs on Morris minors. (1- 1/2 PSI )
I have one on my 28 Top Hat with a 1" SU and it works quietly and reliably.
Best to put a small Motorcycle disposable filter on the inlet side to protect the valves from tank grit.
They retail at $135 here in NZ.
The company owner is a Toolmaker and is very helpful and knowledgeable about his product. He sells many to the Morris minor Clubs and Parts Suppliers worldwide.
Car type: RN box saloon
I think the Fuelflow pump is the one I fitted to my MGB almost thirty years ago. It gives the reassuring Tick Tick until the carbies fill and once the motor is started I can't hear it.
Looks like a well designed, appropriate pump. They're available in the UK for much the same price:
https://simonbbc.com/fuel-flow-su-replac...tallation/
Suffolk, UK
1925 Chummy
1934 Box
I have run a Facet pump in my single-seater for 8 years or more.The space saving compared to an SU is very useful in this cramped environment. VSCC wont accept them.The "tick" changes in timbre when tank is dry.Rubber mounting advisable.
Car type: Ruby1936chassis
08-12-2020, 12:00 PM
(This post was last modified: 08-12-2020, 12:01 PM by John Gould.)
Thanks so much for all the useful advice and info. I guess I should explain why I'm looking to fit one. I want a very early 'look' to the underbonnet area and so I've got the manifolding and carb (Zenith 24T) for an updraught system but I expect it will preclude the use of the AC mechanical pump. For the same reason I don't want to see or hear an electric pump under the bonnet. Ideally I'd have a small, quiet low pressure inline pump halfway along the chassis or at the rear tank. The cheapos look ideal but .......?
Sadly I've a bit of a thing about SUs as I've suffered from them over the years (including being trapped in a crashed Mini listening to the joyful ticking of its pump) but one of the Fuelflow pumps could be a contender. Which one fits at the tank and would its pressure be low enough?
Thanks again folks.
