How long is a piece of string? Race engines
#21
(06-11-2020, 12:09 AM)Charles P Wrote:
(05-11-2020, 09:38 PM)dickie65 Wrote: The late Dave Flake  ( Quarry Engineering ) made patterns for Ulster Nippy and Grasshopper crankcases as well as other castings.
So there are castings and patterns out there somewhere.
Someone must Know !!!
Well here's a 10 stud Ulster that I've nearly finished. Charles
Those Deckel-type millers are just so useful! http://www.lathes.co.uk/deckel
Very much so. Expensive, but good. Pity that Maho accessories are rarer than rocking horse stuff.
You couldn't do this if you had a Bridgeport in your shed.
Charles
It is now at  $5000! A few days to go.
Note the axle looks more bowed than a standard sports axle. Curious about the crank. Is it a Phoenix? It doesn't seem to indicate.
Erich in Seattle
It has a Don Rawson built 3 bearing engine.
So probably Reliant crank and rods, Hillman oil pump, Austin crankcase and Austin cylinder block.
If anyone is interested, now I have rebuilt a correct Speedy engine, I am selling my pressure-fed Pigsty engine. See sales and Wants.
$5500.....Two days to go!
Sold for $ 18250 Some fortunate person has a bargain! Makes all those backyard specials look very expensive!
I have a Nippy Pressure fed Nosepeice from him, I could not afford a crankcase at the time.
Hi Folks,
Its a Don Rawson.
Tony has castings for sale un-machined. IIRC they are the stock from Quarry but happy to be corrected.
http://www.7ca.co.uk/Castings.htm
I understand that Tony Sold the patterns on.
