A7 Jarvis survivers.
Anyone want to commission one......................?
good company...
http://www.coachbuild.com/forum/viewtopi...23&start=0
(09-01-2018, 09:42 PM)Martin Prior Wrote: Anyone want to commission one......................?
Tempting ...
I have a LWB chassis as a basis, so a Jarvisesque special would be 2" wider and 6" longer than the original, even at 6' I should fit ! It helps having been evacuated in 1942 ! My Cup special is also LWB and that has quite easy access due to the extra width and leg room.
It's not attached to a Seven but I do know where there is Jarvis body. When I get time I will photograph and post it on the Forum.
Chris
As promised,         a couple of shots of a Jarvis body attached to an MG chassis. Sorry about the poor quality but conditions in the storage were not ideal.
Chris
