Hello can anyone tell me the correct size of a RP saloon windscreen please (1932)
RP windscreen size
03-11-2020, 06:00 PM
(This post was last modified: 03-11-2020, 06:03 PM by Jeff Taylor.)
The chrome on brass RP screen which I bought for my Van is 35 5/8" edge to edge width across the top x 12 3/4" if you ignore the top hinge or 13 1/4" if you include the top hinge depth wise.
03-11-2020, 07:20 PM
Thanks Jeff is that the glass only, ?
03-11-2020, 08:17 PM
Is it the glass size you are after Graham ?
03-11-2020, 10:56 PM
No Graham, the dimensions I gave above were the maximum external size of the windscreen frame both excluding and including the top hinge. Unfortunately I don't have the precise size of the actual glass sheet as my screen is complete with its original glass intact.
03-11-2020, 11:54 PM
Graham,
The glass size for the windscreen is 34 15/16" x 11 15/16" x 1/4"
Yes Nick please I had one cut years ago but I don't think it was for the RP
If you can help Many thanks Thank you Chris that's great !, Cheers Graham
04-11-2020, 08:58 PM
Hi Graham - do bear in mind that a RP screen is toughened not laminated.
This is better in this car.
04-11-2020, 09:49 PM
Interestingly the Austin Service Journal shows the RP windscreen glass could be had in either " Plain , " Triplex " or " Triplex Toughened ".
04-11-2020, 10:13 PM
Thanks folks, I shall get one made, it's just the corners to get right hahaha
