03-11-2020, 08:54 AM
Or has someone cut the hole as a quick and easy way to attend to a coolant leak or de-sludge the block water jacket
We used to do this to 100E Fords to repair a leaking rear core plug, directly under the dipswitch iirc and then once you'd blocked it with a body plug the customer would be none the wiser...
![Smile Smile](https://www.austinsevenfriends.co.uk/forum/images/smilies/smile.png)
