2 WINGS, BONNET, prop-shaft for RP
Two wings (nearside FRONT, offside FRONT), probably RP, no serious problems that can't be filled.
One bonnet, probably for RP.  Will gladly MEASURE.
Propshaft for RP, 3 prong front for flexible coupling (not fitted), back HS flex' joint OK.
Must be collected from Stockport.
Call Mike on 0771 288 7993
Do you have pics of the front mudguards?
I can only suggest you give me your email address. I don't seem to be able to post images??
I have also given you access to my DropBox
But technology is to complex - so I know email works
beeaware@icloud.com or 0771 288 7993
