12-09-2020, 12:03 PM
Does anybody know where I can get a bendix pinion for a bacon slicer starter?
Bacon slicer bendix pinion
13-09-2020, 07:11 PM
I've never seen a pinion in such bad condition. I would want to know what has caused it?
18-10-2020, 05:06 PM
Clever stuff, David. So the "hold-back" spring (with plunger) now works in the original way instead of the "snap-over-the-gear" spring you made previously to hold the parked position.
18-10-2020, 07:35 PM
Yes I found a suitable mushroom head rivet and a spring, so It's all back as it should be although the weight is a tad heavier.
20-10-2023, 08:45 PM
I've just been given another bacon slicer to fix, the pinion on this is missing the weight until I looked inside and found it flopping about and the commutator been undercut to some depth, I'll give it a good clean and see if I can fill the slots with Araldite unless anybody got any better ideas.
