Hi Nick
Would it be worth a shot of “RedX” down the plug hole? I’m not sure if RedX is still available but it could clear a sticking valve?
Whilst Redex is still available, it's not the Redex of old that we all remember. I don't know if it does much good but these days I put a shot of self mixing two stroke oil into each tank of petrol on all my Sevens.
I had a Seven that read a dizzy 22psi+/- on all cylinders. It ran very sweetly and stormed up quite long hills at a steady 20-25mph in 2nd (out of 3). Starting was a bit of a ritual (the starter struggled to turn it over!) unless the ignition was fully retarded then it immediately burst into life.
Any comments?
Nick,
Read 75 on another car.
D...
