30-09-2020, 01:32 PM
Sorry Dave, another red herring
Air pressure gauge
30-09-2020, 04:23 PM
This is on Amazon in US, so has an NPT connector. Face looks reminiscent of the David Harcourt gauge. There is a Kodiac version that looks identical, but presumably has better internals at twice the price.
https://www.amazon.co.uk/dp/B00FBPPY1Y/r...DFb427RV5G
30-09-2020, 08:42 PM
03-10-2020, 11:25 AM
would this one suit you or be modifiable??? https://www.prewarcar.com/311414-flanged...ge-special
03-10-2020, 12:06 PM
Too high a range Michael,10 psi full range would be max.
I bought a low pressure gauge 2",new modern industrial type off Ebay a while ago with the intention to convert but it would be nice to come up with an original gauge similar to the rest I already have if possible.
03-10-2020, 03:15 PM
(This post was last modified: 03-10-2020, 03:45 PM by Peter Sweeney.)
I used a standard A7 one on an oil drip feed on a 1898 Panhard. The pump came from a paraffin lamp and the rest I made from copper pipe, sheet and brass fittings. The gauge between the air reserve and the oil tank. The first I made with 2 pumps worked but needed more attention. 2 Brighton runs no problems. Pete
I should have said standard oil pressure gauge. Pete
21-10-2020, 12:30 PM
I found a suitable smiths 5 psi oil gauge to convert with a good face. However Greg Clarke has produced an excellent 0-5 reproduction too as would be fitted to Bentleys etc.
21-10-2020, 07:58 PM
21-10-2020, 10:20 PM
Looks very good.How did you do the face,Robert ?
22-10-2020, 07:47 AM
Tony B can supply a face which you can colour to suit your other instruments.
Or you can print your own on coloured paper. If anyone knows a good screen printer who would be prepared to make small batches I would be very interested. |
