08-09-2020, 03:07 AM
HI MALCOLM,
regarding springs one option is to experiment with the dimensions of the individual leaves ( IE ) going from the main leaf up make the third the same length as second or alter the thickness of the main leaf to compensate for weight of the driver.
one problem with bump stops is you do not want them in contact in normal movement of the axle.
and any form of damper is just that to slow the movement not to stop it
just my observation.
Looking like a great project
Colin
NZ
Colin
NZ
