03-01-2018, 06:08 PM
Hello friends
I am trying to set up the brakes on my 1936 Ruby special, but the handbrake Operating lever on the cross shaft is too far to the near side of the car. There is space on the cross shaft for it to slide along to make it directly under the roller that is at the bottom of the handbrake.
It is secured with a cotter pin, if I remove it, is the flat on the cross shaft wide enough to allow it to move along the shaft about 1/4"?
Thanks
Andrew
Thanks
Andrew
