30-08-2020, 09:04 PM
Hello all, I have a few questions about a starter motor I'm trying to revive on my 1934 Box Saloon and would appreciate some pointers.
Firstly, underneath the armature inspection cover there is some sort of gasket which has become extremely brittle and disintegrated on removal. Is the purpose of this simply to keep muck and rubbish out of the inner workings, and can I replace it with standard gasket paper?
Secondly, in the workshop manual it says to grease the armature shaft splines, but not the 'quickthread'. I can't work out why I wouldn't grease the quickthread, and it appears to already be lightly oiled.
Finally, I'm a bit concerned about why the starter motor originally failed. It was long enough ago that I only recall lots of smoke and rapidly disconnecting the battery, followed by the top lever being absolutely seized/melted in place. The copper contact button on top of the motor was absolutely filthy and has taken some cleaning, but I'm not sure if this would be a cause or a symptom?? I've ordered myself a battery isolator as a precaution should it happen again!
Any help much appreciated as always!
