29-06-2020, 08:33 AM
1938 Rear axle
29-06-2020, 11:43 AM
The CI 1A7675 measures 1 1/8" in length.
30-06-2020, 08:11 AM
Strange?
I have the spacer from my axle in front of me. It seems to be a 1A 7660, but no part number. Dimensions: Outside dia. 1 1/2 " Inside dia. 1 1/8 " Length 3/4 " but with a burr and some fretting. I wonder in what way the pinion shaft and housings were amended in September 1938 to allow for a difference of 3/8 " ? This is the pinion assembly that my axle has, late '37/ early '38....
30-06-2020, 09:32 AM
(This post was last modified: 30-06-2020, 09:51 AM by Colin Morgan.)
The alteration shown in the Sept 38 Journal is for the heavy Big Seven type axle. Does this explain the difference from yours?
30-06-2020, 10:12 AM
I know the spacers are often worn but only when something is loose. Why is this so common?
30-06-2020, 03:09 PM
(This post was last modified: 30-06-2020, 03:12 PM by Steve Jones.)
![]() Here's a 1A7675, Henry. As you can see it's cast and marked with the part number. The dimensions are: O/A Length:1 1/8" Ext. Dia: 1 9/16" and 1 11/16" Int. Length: 7/8" plus 1/4" lip Int. Dia: 1 3/16" then 1" at lip Steve
01-07-2020, 09:57 PM
I have tumbled upon few good dwgs of the layoutof the post 1933 axles but the one above is a good representation even though the bearing retaining nut is not obvious as such or the location of the shims. For those unfamiliar may be worth retaining.
