Hello I hope that somebody might be kind enough to explain the workings of the PA speedometer as fitted to my 1928 Austin 7.
During a recent test run travelling at 45-50 mph the needle started to behave erratically for several seconds before returning to zero and occasionally assuming a new position on the dial. I have checked the cable drive at the gearbox and the cable itself, both are in working order. Could any of your readers please advise whether the speedo can be repaired and would parts be available Thank you.
Car type: 1932 RN saloon
You may have lost your balls which was my problem about 30 years ago. Seriously if the balls have fallen out of the bearings I removed the remains of them and then screwed together the male and female parts of the bearing with a few thou running clearance. Worked ok since then ie for many miles.
Cheers,
Dave.
Chris Clark, or his son Greg, will do this repair much cheaper than Speedograph Richfield, I would imagine. You can mail Greg at:
Claudia_louise17@hotmail.com
Thanks to all for your helpful replies as to the workings of the PA speedometer. As the cable on my car is not frayed nor binding against its casing I expect to find that some of the balls have gone missing from their races.
This forum provides a wonderful service by experienced operators who are happy to share their expertise with others less knowledgeable.
The speedo on my 1931 RL saloon has a gremlin. It was rebuilt 20 years ago by Ron Bailey, ex Rolls Royce millwright, and was the most accurate speedo and odometer of any vehicle I have ever had. It never ceases to amaze me how inaccurate many modern speedos are. They tend to read fast so you think the performance is great and record higher mileages so you think the fuel consumption is also great.
I digress. The RL speedo was working perfectly one day then next day I found that it was still working but the needle was 20mph too slow, so it was reading 10mph at 30, 20mph at 40 and I was going a bit at 30mph.
It has a newish cable and the odometer is working perfectly.
I don't think I've lost my balls (yet!) but is it simply that my pointer has drooped?
I have used Chris Clark many times. He does a wonderful job and is very reasonable
