19-05-2020, 09:05 PM
It would be interesting to know how the brakes balance, also with the brake pedal there where does the clutch pedal go Ruairidh?
Restoring a Top Hat
19-05-2020, 09:13 PM
Here Dave...
![]() The throttle linkage is an absolute hoot! Will try and find the picture.
19-05-2020, 09:30 PM
20-05-2020, 09:20 AM
That tiny throttle linkage is hilarious!
20-05-2020, 11:36 PM
I thought the engine was mirror image ?
20-05-2020, 11:57 PM
21-05-2020, 01:23 AM
Thank you for this
26-05-2020, 07:15 PM
This weeks work
Or rather last week, I'm all behind! I was still stuck waiting for the engine bits to return so decided to have a go at the front inner wings. Didn't have a lot of time last week as I had to work 2 1/2 days but managed to sort them out. The offside wasn't too bad, some badly MIG'd over-patches had to be ground off and new metal let in properly. I don't usually bother to grind off the weld beads, they add character I feel! Nearside was in a poor state though, the panel had been repaired several times and was in a bad way. I had to chop off the last inch and let new metal in and then bend it in the right place. I think it's OK, we'll see when I start fitting the front wings...... Fortunately, the balancing shop is back in business and rang at the end of the week, so I went down and collected the crankshaft/flywheel/clutch/rods assembly on Friday (observing correct social distancing rules of course). This week is all about engine rebuilding, which I want finished by Sunday. I have a couple of weeks left but I'm then back to work full-time in June......
26-05-2020, 07:54 PM
Excellent
But work.... “Curse of the Austin Seven Classes”.... Cheers Howard Retired 17 years ago ?.
26-05-2020, 08:20 PM
As you say that is a hoot whilst the clutch pedal is interesting.
