My carburreter is a Zenith downdraft 30 vm-4 and the car is a pig to start. We thought we had traced this to a worn out mechanical fuel pump as the flow was slow. After replacing it with a new one the flow was really good and it seemed better but if left for a few days it is still very hard to start. I have found that if I remove the float chamber and fill it it starts immediately. I have also replaced the flow valve in the top of the float chamber. Any ideas?
Car type: 1932 RN saloon
Have you made sure that the choke is fully closed especially this time of year? I had the same problem with a zenith downdraught. I missed the fact that it wasa tiny bit open even when the choke button on dash was pulled fully out. The cable had slipped slightly on the lever connection.
With 30VM's, in fact any high level carb and mechanical pump, I find a few strokes of the fuel pump priming lever usually gives an instant cold start, after that no issues. As Dave says a fully closed choke helps and it is also worth checking the idle circuit is clear, they can sometimes be blocked and cause problems. If you lack a priming lever a couple of turns on the handle prior to turning on the ignition will have the same result.
What about the old favourite, stale petrol? It doesn't take long for it to go 'off' these days. A drain and refill with fresh might do the trick.
I have the filter off so I can see the choke and it's definitely closed. Definitely not stale Petrol as I have just thrown the old away and put fresh in. I am interested in the "idle circuit" as I don't know what that is. Could you explain please? I am sur the clue is that if I fill the float chamber it starts immediately.
