15-05-2020, 09:31 AM
(This post was last modified: 15-05-2020, 09:34 AM by David Stepney.)
Hi Dellie,
You should also have a flat channel stay that runs under the central bonnet hinge and bolted to a lug on the radiator shell with a similar lug on the scuttle.
-oOo-
Hi Mike.
You could very well be right!
Hmm.That would suggest that the lower flitch panels (to which the bottom of the radiator shroud is bolted) are not properly aligned. I notice on my RP saloon, that the holes in the flitches are slightly elongated to allow for a little adjustment. Every time I have had the radiator off, I have had to tinker to get the radiator aligned and the bonnet to fit satisfactorily.
I think the period shot of a Chummy in Wales is on Bwlch-y-Groes, a well known test hill that featured in many pre-war reliability trials. Sad to relate it is a road I have never driven over but one that is on my bucket list.
Aligning the flitch panels is a tricky job, as the front end sits on the curved cow-horns. These vary in profile and may not be correctly mounted. Until tightened down, the cow-horns can move fore and aft a bit which can cause problems. Elongated holes in the flitch plates and radiator cowl help and everything should be assembled loose until the end. The radiator should be under no strain at all, it can be almost held in place by the hoses alone, and the radiator cowl should not be a force fit otherwise it will be subject to strain and will crack.
Even people who have built many Austin 7's over the years have fun and games fitting the radiator cowl, sometimes you have to resort to making new flitch plates. It is a case of persevering until it looks right and everything bolts together nicely without having to fight it.
15-05-2020, 10:48 AM
(This post was last modified: 15-05-2020, 10:49 AM by Mike Costigan.)
Both the flitch plates and the radiator shell should have oval holes to allow for adjustment; if you slacken off the bolts and twist the radiator shell clockwise (seen from the front) that will straighten the shell and align the starting handle hole more centrally. By triangulating the location with the top channel it should be adequately rigid.
Edit: Malcolm beat me to it!
And, Yes, Dellie.The panel you have circled is the one we are talking about.
