12-05-2020, 10:15 AM
(11-05-2020, 05:23 PM)Steve Jones Wrote:(11-05-2020, 04:28 PM)Charles P Wrote:(11-05-2020, 03:35 PM)Steve Jones Wrote: The set I've used for a long time is a Sealey AK724. Contains 1/4", 5/16", 3/8" and 7/16" extractors. Each also available individually. Coupled with heat at the base of the stud, pretty much works every time.
steve
Agreed.
I find that using oxy/acetylene and getting a lot of localised heat in quickly works much better than fanning it with a DIY butane torch.
c
Agree, oxy/acetylene rather than a butane torch. The block for my new Ulster engine had studs in a worse condition than those in the original posts and all came out without breakages, manifold studs as well. If you do break a stud, the drill guides as detailed in Woodrow work very well when used with the cylinder head. Simple to make if you have a lathe or know someone who does.
+1 on Oxy-Acetylene. Good and hot then a pair of Vise Grips, tighten slightly first then untighten a bit. Backwards and forwards until you can get near enough 1 complete turn. Then you have a fighting chance but they still will break.....
